How To:Front Str.t assembly w/ SS springs and Moog everything else(Finalized 6/5/15)
I addressed that in Post #18 right above the last pic. In the write up I say while the spring is compressed to tighten the locknut enough to touch the isloator, the orientate the shock correctly, then free the spring, then finally go back and and tighten the locknut completely using a 1/4 inch open ended wrench on the shock shaft and an adjustable wrench on the locknut. Even with the spring decompressed you can still tighten the locknut
I would assume if it's not tightened then when the car rebounds the slack in the untightened (loose) screw would cause the assembly to rattle.
Installed BMR Springs and Koni Shocks on my Sons Firebird this weekend what a difference in the ride and look of the car. This thread was a help, still think it should be a sticky!
YOU sir...are the man! I just ordered a set of Koni STR.Ts and want to use my stock springs. But I started thinking that it would be a good idea to use new parts and just put the new assembly after taking the old ones out. I'm going to order stock springs anyhow so this is great.
So the Moog mount being smaller was not an issue? I'm assuming that you installed the new shock/spring setup into the car already. Also, where can I dispose of the old assembly? Do you guys just take them to Autozone, etc and they dispose of it? I'm really not looking forward to dealing with that rusted nut. Another reason I want new parts. Sorry for the stupid noob questions. I have only done brakes, the upgrades in my sig (except the weld on SFCs), and stereo equipment so far.
I'm hoping to have all necessary parts by the time the weather starts to cool down a bit and I can take my time doing this over a weekend or two (or hell even three). I am so glad the search function found this post. It is a life saver.
So if I purchase some Koni STR Ts front and rear, are these additional parts/setup a requirement? Car is a 98 SS with Eibach Pro springs currently and autoparts store shocks.
This is an excellent thread that I'll be referencing for my Koni STR.T and Strano spring installation in the next week or two. My Z28 has always been garaged and has low miles, so I may try to reuse the original shock mount parts. However, I'll probably order spare parts in advance so I have them on hand. One thing that may help some is a bill of materials rather than trying to read the part numbers off the boxes:
(1) Moog K6516 Front Left Upper Strut Mount Kit
(1) Moog K6517 Front Right Upper Strut Mount Kit
(2) Moog K6573 Strut Bearing Plate Insulator
(2) Moog K80927 Lower Spring Seat and Spring Pan (spring pan is not used - as mentioned in the thread as its ID is too small)
The Rock Auto price for the above (6) pieces with shipping is around $151 as of today. Amazon has the same parts for $163 with free shipping. While Amazon is $12 more I might be able to return them for no charge if I don't need them.
Also, my local O'Reilly's wants $49.99(?!) to rent the spring compressors, so I went ahead and bought a set of Craftsman spring compressors (P/N 49289) for $50 with a lifetime warranty. Seems like a no-brainer since I might be needing them for another vehicle soon anyway.
#32
I'm still trying to piece together all my parts as I'm also looking to tackle the bushings as well. I am debating on whether to get a set of spring compressors or just use a hydraulic press at the hobby store on base.
#33
Just curious, would it be a good idea to fill the entire void of the upper shock mount with silicone caulk to prevent this? Sure seems like a cheap way to preserve the nut & threads on the upper mount and prevent crud from getting in there, at minimum maybe a bead of caulk around the edge to seal it from the elements:
#34
#35
Pictures are easier to explain than with words alone...
I put antiseize on the nut and threads (white) and I also put antiseize on the isolator (red) but you could put synthetic/marine grease on the red portion as well. You could put grease over the entire isolator and part of the mount if you so desire, but I don't think it's really needed that much
#37
Thanks to ROLEXRifleman for this how-to! As of today My Z28 now has Koni STR.Ts and Strano springs front and back. I reused the OEM shock hardware instead of Moog parts, which were still in great shape. I used plenty of anti-seize and synthetic grease in the right spots. The Delphi shock isolator needed some grinding to fit into the Koni spring seat, just like the Moog part. A pass or two on the grinder did the trick. I'm very pleased with the results.
#38
OP, how do you like the ride? Im in the process of putting together the same setup, coming from stock struts and sagging eibach springs. Before I get lit up, I bought it that way 6 month ago, just now had the time to fix it.
#39
Fairly similar design, if you ask me. I read somewhere that they're some type of coilover. Other than pulling the trans, changing brakes out, and what I just did, I am a complete T/A rookie. I just came from a lightly modded 03 GTP in search of a faster, more iconic Pontiac. Got what I paid for, no question.
