What's hurting me more, poly LCAs and TA or 23mm rear sway bar?
Running a 32mm WS6 front sway bar and 23mm 91 formula rear sway bar, and poly ended LCAs and a poly ended Spohn short TA, which is causing the oversteer more? I'd like to keep the rear bar if possible for removing the front bar and having a cheap drag bar at the strip, but its loose on backcountry roads.
Id bet the rear bar, that thing is big.
Why not just add a 35mm or 36mm front bar to compensate?
Ditch the poly LCA's for rotojoint or something non-poly, and ditch the short torque arm for a full length one, the car will feel much better afterwards.
I had a 9" with 4.33s and a spool with the rotos, and I hated it on the street, got frustrated and sold that setup and went too far backwards for comfort again. Ill do 1 sided rotos eventually, I got these super cheap. It wasnt loud, the shitty setup 9" sent so much vibration through my *** if I was a woman Id be orgasming the whole drive. As you can see Im not making enough power to set the world on fire, I just needed to keep something to prevent wheelhop to save the 10 bolt.
+1 on this, I have a BMR front 35MM solid (poly ends), and rear 21 or 22 mm solid (poly ends) on Sara (2001 Z28), and from a dead stop, if I give it too much acceleration, the rear end wants to come around on me.
Sara is great on cornering, she drives as though she is on "rails".
Once change at a time, swap out the rear bar since it's easier than changing LCA joints. Then see how the car is.
Also...are your tires old/bald? Shitty rear tires will let you be tail happy as well.
