Short tunnel mount torque arm or convert existing with bracket?
Setting up a car that was mildly modded for a new setup:
Nitrous M6 car, 800+rwhp
Will see 75% street, 25% track duty.
Not a daily driver. Not a cruiser.
It already has the BMR adjustable full length torque arm. I want to get the mount off of the tail shaft housing. Should I drop the coin on a new short arm with tunnel mount or just buy the $250 tunnel mount adapter bracket?
Does the short arm make that much of a difference?
Other relevant items the car has:
Adj LCAs
LCA relo brackets
SFCs
NonAdj Panhard
Viking Dbl Adjustable Rear Shocks
BMR 1.25 rear drop springs
Viking Dbl Adjustable front coil overs
Strange S60
Adj LCAs
LCA relo brackets
SFCs
NonAdj Panhard
Strange S60
Hello, The short torque arms are geared more towards drag racing and would work very well. However seeing you are 75% street and already have a torque arm I think the relocation kit would be the best bet for you. Our UMI #2207 would bolt right to that BMR torque arm and so would a BMR unit.
I hope this helps,
Ryan
I hope this helps,
Ryan
LS1Tech Premium Sponsor
Like Ryan @ UMI said I would recommend just grabbing a torque arm relocation crossmember to go with your existing BMR adjustable torque arm and you will be good to go. With you already having the torque arm and the car seeing more street duty than track duty it will work well for you. If you have any additional questions or if we can help you out with anything let me know.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
I've had both. Installation/pictures and initial driving impressions can be found here:
https://ls1tech.com/forums/multimedi...cs-vids-8.html
Give us a call and we can go over some details. (309)382-6252
