Brake pull
Old 02-29-2016, 10:11 AM
DirtyBird2000's Avatar
Default Brake pull
I have a 2000 ws6 and about 4 or 5 months ago my ABS light came on. Fast forward to last week and I did the CTS-V 4 pot conversion. The brakes have always pulled to the left, but with the upgrade it has made it that much more noticeable. I cannot figure out why my ABS light is on and if the brake pull is related to the light. Any help is appreciated, thanks.
Old 02-29-2016, 11:49 AM
Cpt.Derrek's Avatar
sounds like you could have some blockage on your right brake. could be a kink in the hoses or lines, or you could have some blockage inside your ABS unit. If all your brake lines look good, how long has it been since you have done a full brake fluid flush?
Old 02-29-2016, 09:03 PM
I havent done a complete flush but bleeding them about a week ago I got a pretty decent amount of fluid out.
Old 02-29-2016, 09:38 PM
Cpt.Derrek's Avatar
I'd do a flush first if I were you. Also make sure your brake booster does not suck up any air.
Old 03-01-2016, 06:16 AM
Save the manuals!
wssix99's Avatar
You should figure this out first by scanning the ABS system. You'll need access to a scanner that can get the ABS codes, of course. Sometimes local parts stores will offer this for free and other times, they wont have the necessary scanner I some areas.
Quick Reply: Brake pull
