Watts Link install-driving impressions
So, after a very long period of time, I finally had my Watts link installed. Along with the link, I had four new bilsteins, front shock mounts and rear sway bar links also installed. Just a bit of history on the car. 2001 Firehawk #117, about five years ago, had a head/cam/LT and tune. Factory bottom end, with AI ground cam and full head job on the 241's. Ok, so even though only making 405hp/390tp at the rear wheels, that was way more power for the factory rear suspension to handle. If I floored it in 1st or even 2nd, the rear would start to get squirrely. NOT ANYMORE! This Watts link keeps that rear planted, no more fishtailing. Haven't tried it on the track yet, but I am happy with the results. At this point, I think I have done everything possible to upgrade the suspension. I recommend this product.
PS. Great customer service from Fays. First contacted Strano about a missing pair of 3 inch U-bolts and Sam pointed me to Jim and I emailed Jim and he sent them Priority mail had them in two days. Buy with confidence.
The Fays 2 IS a high quality piece, but I am holding off for the UMI version, hoping that they will make some improvements over even the great Fays 2 design.
Very nice! You will love it at the track, biggest improvement I noticed is that coming out of a corner you can get on the power a lot earlier without sending your *** into a wall. Mess around with the roll center adjustment holes, as I found it also improved my understeer.
Curious
I'm new to upgrading and mods....until now I never had a car worth it. I have a 98 TA with all stock in the rear. I want to get a watts link but my question is, I want to beef up the suspension so do I wait until I'm done with that first? Thanks in advance!
A Watts link is a rather expensive mod so I don't think most would start with that, though it is a great mod IMO. Depends on how worn the parts on your car are and what you want to do with the car, how much money you have... a lot of factors. Most start with shocks and springs.
It depends what you will be doing with the car (daily street? drag racing? canyons? autocross?). Since you are starting out, and my car is a daily, I will approach it from that angle.
If you can swing it, go for the Koni Sport "Yellows" (all 4) and a set of Sam Strano's 35mm/22mm antiroll bars. Your suspension will be much improved with just those two, but you could go all-in and and get Sam's full Handling Package 7 (as I did) which also lowers the car about 1.25". Be prepared that the car will be much stiffer, and the nose will scrape many driveways, but the handling will be truly rewarding. If you go this route, I suggest an adjustable panhard bar to center the axle, and you might as well replace any worn out bushings and ball joints with MOOG pieces while you are in there (don't forget rear bump stops). Wider wheels and tires in the 275mm width will also help handling a lot if you don't already have them.
LS1TECH Sponsor
While I was the first one here to be running and selling a Watts link, and the one who had to argue how it was better (from experience gained) than any PHB, I will state right here and now that in no way would I put a watts link on a car that is subpar in other places.
Good shocks have to lead the charge. Not new shocks, GOOD shocks. Minimum Bilstein or STR.T but ideally Koni Sports or an appropriate for handling coil-over. It doesn't make sense to not deal with the worst part of the car which is the dampers first. And if you want a really great handling car, mediocre shocks aren't the ticket either.
Now, you can decide from there if you want to lower it, put sway bars on it etc. None of those are required to see a benefit from the Watts link.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
I will second (or third) the recommendation for SHOCKS FIRST. And Koni yellow (sports) are the way to go. Even if you don't autocross, put them on, put them to the softest setting, and enjoy greatly improved handling and still a nice ride quality. FWIW I had Koni's and stock springs for many years and it was a great combo for driving and AX'ing. Turn them to full hard and then it's better for AX but IMO the street quality suffers as bumps really start to bang you around a bit more.
@TAGirl111 you shouldn't get a watts until after you've done Koni shocks and front swaybar.
LS1TECH Sponsor
Koni's do still have the mail in rebate progam going on through the 31st. Sports you get $50 back on a set. And I have front bars in stock too.
__________________
LS1TECH Sponsor
It would work better than STR.T front, Sport rears. You could do worse, you could do better but you absolutely could do worse. I'd try it.
__________________
