1999 Z28 Rear Calipers
I was doing the rear brakes on my 1999 Z28, switching to drilled and slotted rotor, adding Hawks pads, and doing braided lines. Because I drove on bad brakes for too long I shattered a rotor and destroyed on of my calipers, stupid thing to do, I know.
Anyway, I'm looking for stock replacement calipers in the rear. I found some Cardone calipers on Summit for $40, compared to the $120+ on Rick's Camaros, and the 140+ on GM Parts Direct. My question is, the rear calipers from Cardone say the don't have provisions for the parking brake, but looking at my calipers the only thing that's connected to the car are the brake hoses, but I know I've used the parking brake before. Will this calipers be fine to put on my car?
Save the manuals!
Yes, no two rotors are exactly alike and the adjustment is done in fractions of a millimeter. Regular drum brakes auto-adjust to the bore of the drum, but since this parking brake doesn't wear down (unless you are a drifter...) the adjustment is manual and it needs to be hard-set for each rotor bore.
The process is in this thread: https://ls1tech.com/forums/suspensio...ke-01-z28.html
While you have everything off, you may consider popping off your parking brake cable and replacing your dust boots. (They get torn up really easy.) This would be the time to do that... If you want a good laugh, this thread has an alternate option. The only known proper source of supply for the OEM boot is in post #13:
https://ls1tech.com/forums/suspensio...xperiment.html
So, I painted the calipers I got from Cardone and have them assembled for the most part. They came with washers, but I have no idea what they are for. Any one know?
