28in tall tire..what lowering spring
Whats up guys, i have a 99 f body with i THINK to be v6 rear springs. I'm not sure. i was told by previous owner it had them in it. I do have a 10 bolt rear at the moment but it won't be there too long. What are you guys using spring wise to lower the car. I know since its a taller tire i don't want to accidentally go too low. I plan on rolling the lip. bump stops are cut out. I have non adjustable LCAs now. Will i need adjustable one? and will i need new shocks?
LS1Tech Premium Sponsor
The problem with running a v6 spring is it is a softer rate, this is what gives the drop. But once you fill the wheel-well up with a 28" tire you will not have much room for suspension compression before the tire contacts the fender well. If you like the stance with the v6 spring and the isolator removed, Our rear springs may be a good option. Our springs offer 1-1.25" of drop and have a 160 lb rate which is 10 lbs higher than stock. This will keep the suspension from compressing too freely and causing tire contact issues
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
