Viking vs. QA1 coilover for street
IMO there is nothing worse than modifying a car with no "goals" in mind. It's money down the drain. Having a plan for better handling/better ride quality/better drag car is the start. Then you research and modify the car accordingly to get you to your goals that fits your budget.
LS1Tech Premium Sponsor
That sounds more like a band-aid to the issue of not being a gas charged shock. Also I think people need to remember that adjusting compression and rebound is not the same as a full revalve. I don't think cranking up the stiffness on a viking shock and slapping some 600lb/in springs on them isn't going to be the same as fine tuning the valve shape, adjusting the shim stack or whatever depending how the internals are set up.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
I currently have a strano/ koni setup on the car and don't like the stance. I did not get the drop on the front that I expected. I am just looking for the adjustability of the coil over to get the stance that I want. Viking and QA1 seem to be the most affordable/popular. I have QA1 coilovers on my 67 camaro twin turbo drag/street car. I only wanted opinions on what is available. I have a set of QA1 with a 325 spring and a set of Viking with a 350 spring that should arrive tomorrow. I only want to use 1 set and the other will be returned. Just looking for opinions on which coilover may be better.
You know you could have sleeved the front Koni shocks and turned them into coil-overs for way less than buying QA1 or Viking shocks, right? You would also get to keep your great ride and handling.
This is the typical drag guy response, they all think that the differences will only be seen when driving at the limit, but I can't blame them because they have nothing to compare to.
You will notice a difference in pretty much all situations while the car is moving, on the street or on a track, driving like a grandma or like a madman, the car will still feel different and behave differently.
The Viking setup is going to do everything the OP wants, period. He wants a coilover and wants ride height adjustability. The last time I checked, the Vikings offer that, and do so at a very good price-point.
It sounds to me like the OP wants something that's better than what he has (stock ****), and again, the Viking coilover setup is going to be WAY better than stock ****. I went from stock **** to the Viking setup, and I couldn't be happier. From experience, when the settings are setup for spirited street driving, the Vikings deliver. You guys get way too caught up in what 99% of us will never experience or do with our cars. Are there other setups out there that are better for the 1% out there who are competitive autocross drivers, yes. Will the other 99% be happy with the Viking coilover setup for their street car, yes.
Even if I never planned on auto-xing I would still be buying Koni SA's (or a even higher end shock) because they make the car drive SO good, and feel like a BMW. I don't see the point in spending the money on drag shocks to have the car drive and feel poorly in comparison unless I was going for absolutely every last tenth of a second in the 1/4 mile on a single digit car, as konis have been 1.5 second 60fts and im sure could go better if they tried.
Im not knocking vikings at all here, Im just calling a duck a duck when I see one.
Just throwing this out there for you street guys....
I'm currently working on some Afco/UMI valved Monotube gas charged non adj. shocks.
Hopefully after testing is complete we will have a gas charged, affordable shock that can be used as coil-overs(with our brackets) or just superior street shocks.
Craig
Craig
