Brakes for weld draglites on the front... HELP!
Old 07-07-2016, 04:29 PM
jhshnh's Avatar
Default Brakes for weld draglites on the front... HELP!
Guys, I'm ready to get some brakes for the front of my 2000 Z. I plan on running weld draglite skinnies and don't want to use a spacer. I prefer not to get a drag brakes setup, as I drive in traffic. Please Help!
Old 07-12-2016, 12:53 AM
BOLO's Avatar
Stock brakes are your best option. Aftermarket brakes are going to be much bigger and you will have issues getting it to fit with the skinny Weld Drag lites. You can also swap to a smaller LT1 stock brakes as well. I'm sure you will be grinding the calipers no matter which brakes you will be going with. Good luck.
Quick Reply: Brakes for weld draglites on the front... HELP!
