What do you guys think of my spring rate?
So I currently have front Viking coilovers on my 97 Turbo Trans Am and DA viking shocks in the rear. I am more concerned with my 60ft than the comfort of street driving. My front spring rate is 350lbs because of the turbo setup. I chose 150lbs springs for rear. Good choice? I do have weight reductions as well.
Some guys run soft spring/stiff bar, some stiff spring/soft bar on the rear.
The best thing to do is run it and make changes from there.
Craig
LS1Tech Premium Sponsor
150 is a normal middle of the road option for a street/strip oriented car. I normally go in the 175/200 range on a handling based car, or down to 125 on a super light drag only car. These cars are pretty sensitive to spring rate changes in the back, so you don't want to make too big of jumps. This is also contingent on total curb weight and desired ride height. It's going to be hard to tell really if the spring rate is off until some hits are made to see how the car responds
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
I would like to know this as well. I street race the car on asphalt so I need all the weight transfer I can get. 250 shot Nitrous car, M6, with about 150 pounds gone off the nose, soon to be 200 pounds gone. Thinking 275# for spring rates up front, viking coil overs but unsure on spring length. This is to hook on non- prepped roads, not the track, but this is a race car.
Might go big turbo in the future though...
