Need help, 4 channel brake line routing
took pictures before rear removal, but not of this. I replaced my hard brake lines that run from abs to rear of car while i was doing my rear swap. Its time to reconnect all lines, but dont know which lines plug into which hard line. If i dont get the lines in the correct side it will screw up when abs kicks in.
My question is, can someone look under their 4 channel car. Look where the brake lines connect to the rubbers, the first set of rubbers right by where the fuel pump electric connectors plug into the car. Does the top hard line go to the drivers side rear brake or the pass side. Thanks
