Need Steering Rack Advice
Old 01-29-2017, 05:53 PM
SSV8's Avatar
Default Need Steering Rack Advice
Hey guys so my steering rack and pinion is leaking plus the tie rod end bushings are wasted. I've been reading and people say not to go remanufactured from your local auto store, but some people seem to like rackdoctor. Is the rackdoctor steering rack a good choice? Or will I be replacing it every so many thousands miles? Also is it hard to rebuild the steering rack? Is it a good idea to just rebuild the one I have with a quality kit?
Old 01-29-2017, 07:47 PM
FirstYrLS1Z's Avatar
here's some past threads
https://ls1tech.com/forums/suspensio...ion-units.html
https://ls1tech.com/forums/suspensio...alignment.html
https://ls1tech.com/forums/suspensio...-rack-buy.html
Old 01-30-2017, 10:20 AM
BrittleSpeed's Avatar
I picked mine up from Rackdoctor.net No problems after a year now. Quality of rebuild was far superior then Cardone. I could tell when I pulled it out of the box that the have quality checks. As many say, stay away from all the local parts stores as they all carry Cardone and they are equally all ****.
Old 01-30-2017, 11:05 AM
Chrisingermany's Avatar
I purchased one from rackdoctor. The first one I received went in and after about a month started clunking when I turned the wheel.
I contacted rack doctor and the sent me out another one. That one came and had some damaged lines so I asked if I could swap them over for the one I am sending back and they said that's fine. New one has been in for about 6 months with no real issue.
Old 01-30-2017, 11:16 PM
SSV8's Avatar
Ok I guess I am going with the rack doctor. So they have 2 different steering racks in their website. One is for the F41 suspension and the other is for FE2, FE4, and FE7 suspension. How do I know which one I need?
Old 01-31-2017, 07:46 AM
Open your driver door and look at that option code sticker. You should see one of those there.
Old 07-09-2018, 06:06 PM
EnergyCC's Avatar
My rack doctor rack started leaking about 2 years after I put it in. Went with an autozone model this time. It was much cheaper.... seems fine for the last 6 months or so.
Old 07-11-2018, 07:31 AM
notsonic's Avatar
I ordered the 2000-2002 rack expecting it to be the v8 rack that takes fewer turns lock to lock, and I received a v6 rack.
I called them up and the guy was super rude. "You think you know more about steering racks than me?" "Why didn't you call before ordering" etc. I asked him to please check my core to be sure about the ratio and he said he could tell just by eyeballing it that it's the same as the one they sent (it isn't). So now, rather than send me the right rack, they're just returning my core to me and sent me a label to return the new rack for a refund. What a hassle. I'm going to be buying my next one from a local store so I don't have to deal with this.
The new rack I got from rack doctor also wasn't centered. 1 and a half turns right, 1 and a quarter turns left. Also that's 2 and 3/4 total turns which is a v6 rack. 2 1/4 total turns would be the v8/performance rack.
Old 07-11-2018, 10:44 AM
If I could do it all over again I would just send my stock one to TurnOne to get rebuilt. My post (#4) from a six months into the second rackdoctor one either leaked and I didn't see it or started leaking shortly after a few months. It leaks and leaves a few drops on the concrete out the drivers side boot every time I park the car. I still have my stock one (never turned it in for a core refund) and over the winter I may send it in to turnone.
Quick Reply: Need Steering Rack Advice
