Newbie trying to do rear end
Old 02-10-2017, 07:41 AM
greend216's Avatar
Default Newbie trying to do rear end
Ok so I'm new to building cars up. I want to take the stock 10 bolt out and replace with a 9 bolt. From what I've been researching the 10 bolt tends to need replacing when you start throwing a lot of power to it especially since I have a 6 speed. My question is where do I start ? How do I know what I need and how do I determine which parts to get ? Like what's spline ?how do I figure out what center section spline number and such.
Old 02-10-2017, 09:46 AM
MidwestChassis2's Avatar
Your best bet is to always go with 35SPL, is it always needed no however if you can you should for possible future growth.
Give us a call at (309)382-6252 and we can discuss multiple different options.
Old 02-10-2017, 11:14 AM
greend216's Avatar
I saw a 9" Moser Ford rear end housing. Bolt in for Fox body Mustang with UPR upper and lower control arms. Comes with two sets of axles, 35 spline gun drilled Moser. Also includes custom made Strange caliper brackets for their drag brakes. Will that work on my car ?
Old 02-10-2017, 11:47 AM
What type of vehicle do you have?
Old 02-10-2017, 11:50 AM
greend216's Avatar
2000 camaro z28
Old 02-10-2017, 12:21 PM
I don't know of any Mustang specific housings that bolt into a F-Body.
Old 02-10-2017, 12:23 PM
greend216's Avatar
That's what I thought. I get confused when I look for a 9 in. Rear end because most of them say ford.
Old 02-10-2017, 12:38 PM
BrittleSpeed's Avatar
9" is a Ford designed rearend that people put in tons of different vehicles. It's not a rear that necessarily comes out of a Ford.
Check out many threads here, but your three main choices are rears are 9", S60 and 12 bolt. Most people will use either the 9" or S60 as the 12 bolt starts to have pinion problems (I guess)
I went with an S60 for my 2000 (see the CRP thread)
Old 02-10-2017, 12:47 PM
Sorry, go to the Gears & Axles section
https://ls1tech.com/forums/gears-axles-15/
Old 02-10-2017, 02:51 PM
Very understandable how it all can be confusing, you are more than welcome to call us and we can help you out with any questions you may have. Giving advice is what we are here for.
Old 02-10-2017, 03:07 PM
greend216's Avatar
Okay thanks I'll be calling to get advice soon
Old 02-12-2017, 10:33 PM
Lanky Gypsy's Avatar
Greend216 your not alone. I'm got some mechanical skills from working the rigs and small farming but the rear end replacement thing is all new to me.
I've been going through a few dozen threads and man I wish someone would help spell it clearly which way to go for replacing a diff on a 98-02 that is the following:
1) most cost effective (less then $2000) for the back yard mechanic
2) basically stock car with option to increase in horsepower up to 400hp
3) whole kit and doesn't require cutting
4) i like the range of the stock - but should I change the gear ratio; what do I change it to. I'd like a little more 0-60 performance
5) best fit for 275/40/17 tires
​​​​​​​I'd really apprecite help.
Old 02-12-2017, 10:34 PM
Old 02-12-2017, 10:37 PM
greend216's Avatar
Lol nice to know I'm not alone lol
Old 02-13-2017, 10:26 AM
Lanky Gypsy
1) Less than $2000 for new is going to be difficult especially for anything with quality behind it.
2) HP isn't necessarily what breaks parts and why you should look into an aftermarket rear end. It is the torque arm mounting style plus the vehicle weight.
3) Not to many quality aftermarket rear ends on the market require cutting, however some like the MWC fabricated housing is the only one that bolts back in like the factory 10-bolt came out utilizing things like brake line clips, brake line bracket, sway bar brackets, and e-brake brackets.
4) Gear ratio is an option you feel best with for your desired application. We can give suggestions but the use of only calculators are your best information.
5) As for tire fitment, a rear end like ours can be built to 100% stock widths or narrowed if you desired it to be. If you want a custom width it can be done, purchase the wheel and tire combination you like. Set them up in the vehicle and give the measurement and any shop that knows what they are doing can use those measurements to build you the correct width housing.
Hope that helps.
Old 02-13-2017, 02:50 PM
Thanks for the very informative information. I really appreciate it! I've been led to believe it was posi and pinion gear that had caused my problems. First time I'm hearing its the torque arm. Good to know the root cause.
​​​​​​The reason I've used 2 grand as a base is to stay married....I like my wife and my car. Lol
I will be in contact with you guys for a quote.
Old 02-13-2017, 03:46 PM
Not a problem, keep in mind we do layaway on all our products. We understand how expensive this hobby is.
Old 02-13-2017, 05:37 PM
greend216's Avatar
How long is your layaway for ?
Old 02-14-2017, 08:14 AM
Layaway works with a $500 non refundable deposit on rear ends and pay on it as long as you would like with no penalties or time limits. Deposit is non transferable to another person if purchaser changes their mind on their order.
We have had a customer pay since 2012 and just recently paid it off and received his rear end order.
Old 02-14-2017, 08:24 AM
greend216's Avatar
Damn lol ok I might have to do that then
Quick Reply: Newbie trying to do rear end
