Keep Losing Spring Isolator - LS1TECH
Thread Tools Search this Thread
Old 03-02-2017, 08:18 PM   #1
KonkeyDong's Avatar
Default Keep Losing Spring Isolator
Just bought a new spring isolator for the rear drivers side. FELL OUT AGAIN? How can I keep that sucker in there?
KonkeyDong is offline   Reply With Quote
Old 03-02-2017, 08:29 PM   #2
Majestic9C1's Avatar
how does it fall out??
Majestic9C1 is offline   Reply With Quote
Old 03-02-2017, 09:20 PM   #3
Tracer Bullet's Avatar
Zip tie it to the spring? How does it even fall out?
Tracer Bullet is offline   Reply With Quote
Old 03-02-2017, 09:29 PM   #4
KonkeyDong's Avatar
Im not sure. Apparently its popping out or something. Im going to call the shop and see if theyll pay for the next one because they charged me $54 each for two. Im going to start doing my own work, just hesitant because I'm not too savvy.
Old 03-03-2017, 05:31 AM   #5
JD_AMG's Avatar
Quote:
Are you sure they even installed it in the first place? Sounds like you were either charged for nothing or they installed them wrong somehow.
On stock springs you have to get the rear in the air with axle hanging full droop, unbolt the shocks to let the axle all the way down and then pry off the bottom of the spring attached to the axle to get the springs off and then get the isolators which if I remember right are tight on the spring, not like they just randomly slip off. I don't see how they could possibly fall out just driving around unless you are on some weird lowering springs that don't extend enough to make contact with the body when the axle is a full droop and then you jumped a ramp and got airborne so the axle could be fully extended and then a bird flew under the car and grabbed them off.
JD_AMG is offline   Reply With Quote
Old 03-03-2017, 12:38 PM   #6
farmington's Avatar
quit with the Dukes of Hazzard imitations
farmington is offline   Reply With Quote
Old 03-03-2017, 01:05 PM   #7
Corvett z07's Avatar
Gotta love it when JD goes off on his tangents
Corvett z07 is offline   Reply With Quote
Old 03-03-2017, 01:41 PM   #8
BMR Sales2's Avatar
One does not simply lose spring isolators
Seriously, those things should be under spring pressure held in place, even with the axle at full droop with the shocks connected. At $54 a piece they better be giving you some good ones. I have used some in place of the stock isolators before form O'Reilly's that are $10 for a PAIR. I still don't know how one would be falling out though
BMR Sales2 is offline   Reply With Quote
Old 03-03-2017, 01:52 PM   #9
Internet Technician
i tape mine on with electrical tape in 3 or 4 spots.
ramairetransam is offline   Reply With Quote
Old 03-03-2017, 02:03 PM   #10
LS1TECH Sponsor
Sam Strano's Avatar
Cut springs? That spring shouldn't be hanging loose at droop anyway.
Sam Strano is offline   Reply With Quote
Old 03-03-2017, 04:05 PM   #11
KonkeyDong's Avatar
Yeah. Theyre loose when I jack the car up. I can reach in there and move em around with my hand, freely. They pretty much fall out when I jack the car up.
Old 03-03-2017, 04:07 PM   #12
LS1TECH Sponsor
Sam Strano's Avatar
Well, then you have a spring issue. Probably cut stock ones. And that means unless you secure the isolators to the spring this will continue to happen. Of course you might be doing this to raise the car up some because when folks cut springs it is hard to know how much and they really have no idea how it effects the ride. Because you gain rate from cutting but not typically enough to counter the lower height.
Old 03-03-2017, 06:34 PM   #13
JD_AMG's Avatar
Old 03-03-2017, 06:38 PM   #14
KonkeyDong's Avatar
So buy some ACTUAL lowering springs, not just stockers cut. Got it.
Old 03-03-2017, 06:39 PM   #15
KonkeyDong's Avatar
How difficult are they to replace?
Old 03-06-2017, 07:13 AM   #16
leadfoot4's Avatar
Support the car on jack stands, at the frame, with a floor jack supporting the rear axle, unbolt the lower shock bolts then lower the jack. Springs should readily be removable, at this point. Place new isolators on top of springs then place the springs in the seats on the axle, with the "pigtails" facing forward. Raise jack and reinstall shock bolts.
If you're worried about the isolators falling out again, you could also secure them to the underbody of the car with a bead of RTV on the top of them, before you put them back in place.
leadfoot4 is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
spring isolator hoonigann Suspension & Brakes 4 03-16-2016 05:02 PM
Rear Spring Isolators steelgraygtp Parts Classifieds 3 08-07-2015 12:14 PM
LSA/LS9 S/C Shaft Wear - Engineering Response Ed Piatek Cadillac CTS-V 2004-2007 (Gen I) 1 11-23-2009 06:32 PM
Rear Spring Isolator Question Jefro6996 Suspension & Brakes 10 08-03-2008 09:30 AM
rear spring isolators ski23 Suspension & Brakes 5 09-26-2007 04:10 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
