UMI Product Update: 4th Gen Shock Tower Brace Now Available in Satin Black
Old 03-09-2017, 10:08 AM
UMI Performance's Avatar
Thumbs up UMI Product Update: 4th Gen Shock Tower Brace Now Available in Satin Black
1993-2002 Camaro/Firebird Shock Tower Brace now available in Satin Black.
P/N 2005 mild steel priced at $79.99
P/N 2006 chromoly priced at $129.99
The UMI shock tower brace connects the front right and left shock towers together for firm handling, improved steering response and protection when running those big sticky tires up front. The UMI brace is constructed of 1-1/4” USA tubing and uses 1/4” thick CNC laser cut mounting plates. The UMI mild steel version weighs in at 4-1/2lbs while the chromoly version weighs only 4lbs. Installation of the UMI shock tower brace takes 15 minutes or less using basic hand tools. Available powder coated gloss red, gloss black or new satin black.
MILD STEEL WEBSITE LINK HERE
CHROMOLY WEBSITE LINK HERE
Old 03-10-2017, 10:58 PM
1bdbrd's Avatar
Will the satin black be a color option for the rest of your suspension and chassis parts going forward?
Old 03-10-2017, 11:09 PM
Super Hulk Smash
JakeFusion's Avatar
And this will clear the FAST 102?
Old 03-11-2017, 01:46 AM
zbugger's Avatar
Apparently it does with the Strano brake booster brace. Comes with a spacer and that might be what does it. Unless they changed the design.
Old 03-11-2017, 08:03 AM
JTtransAM's Avatar
I heard the same thing about the Brake booster brace. The pic in this thread looks like a 92mm though...
Old 03-11-2017, 10:56 AM
Picture is a 92mm correct, we are going to work on a FAST 102 so hang in there! The Strano bracket is installed on that car as well, it's black.
Satin black right now is just the shock tower brace since it is has a cosmetic appeal to it. The color is awesome, it has a slight texture to it. I really like it and our sticker seems to top it off.
Old 03-11-2017, 03:19 PM
2ToeRacing's Avatar
I had my subframe connectors powdered in flat black.looks great under the car
Old 03-11-2017, 07:36 PM
1bdbrd's Avatar
It would be amazing if this worked its way to the other suspension components as well. Either that or a discounted option for no powdercoating at all so we could do our own custom colors.
Old 05-08-2017, 08:13 AM
KILLERARMY's Avatar
What's the latest info about the STB that can fit over the Fast 102 intake?
Old 05-09-2017, 07:52 AM
Mike Morris's Avatar
X2 please
Old 09-20-2018, 05:52 PM
KILLERARMY's Avatar
It's been a year and some months and still no new info about a STB that can fit over a 102mm FAST Intake? help use out UMI Performance
Old 09-20-2018, 06:12 PM
z-maro's Avatar
I am also looking for an STB to work with my fast 102. Was thinking of trying the BMR V6/ LT1 SS version but don't know if it will fit with the strano MC brace. Looks like UMI stopped making their V6 version..
Old 09-20-2018, 07:21 PM
banshe5's Avatar
The V6/LT1 SS STB will not fit with Strano’s Master Cylinder Brace. I tried and didn’t even think about it, I got it cleaned and painted SOM. I went to install it and no such luck.
Old 09-20-2018, 08:49 PM
z-maro's Avatar
Dang, I thought it looked like there could be an issue with the pictures I've seen of it. Thanks for the heads up!
Old 09-21-2018, 12:16 PM
Chrisingermany's Avatar
With the small spacer plate that comes with the Strano Brake brace, the UMI STB will clear the 102 intake. I installed the plate under the passenger side and that was enough to clear without issues. I am also running UMI solid motor mounts that may or may not be a factor.
This was just a mock up of the space needed
Old 09-21-2018, 02:47 PM
z-maro's Avatar
I tried that with a founders STB and stock motor mounts and it was not successful. With the amount of spacers needed I think I would have ran out of thread engagement on those bolts.
Quick Reply: UMI Product Update: 4th Gen Shock Tower Brace Now Available in Satin Black
