car sounds like a barking seal when turning - LS1TECH
Thread Tools Search this Thread
Old 03-19-2017, 08:30 AM   #1
AdsoYo's Avatar
Default car sounds like a barking seal when turning
This has been getting gradually worse for a few years. Now it's to the point I want to fix it. I notice it only when making 90* turns, like onto side roads or into parking lots/ parking spaces. It sounds like one of the wheels is barking like a seal. Car drives and handles great. I can't tell which wheel it's coming from. It doesn't sound like dueling seals so I'm pretty sure it's just one wheel. Last year I had a creaking noise along with this seal noise and that ended up being dry ball joints. The creaking noise went away after greasing the ball joints but that made no difference to the seal noise. Any ideas?
AdsoYo is offline   Reply With Quote
Old 03-19-2017, 09:13 AM   #2
M4N14C's Avatar
You sure it isn't the ps pump? A bad or weak pump will make all sorts of noises in those situations. If not it could be the hubs
M4N14C is online now   Reply With Quote
Old 03-19-2017, 11:18 AM   #3
AdsoYo's Avatar
Quote:
Yeah I'm sure it's not the pump. If it's the hubs is there a way to fix it or do I need new hubs?
Old 03-20-2017, 02:27 PM   #4
M4N14C's Avatar
If only one side is doing it then swap hubs to the other side and see if the noise changes to the other side. Does the noise get faster the faster you go?
Old 03-20-2017, 03:47 PM   #5
blackbyrd's Avatar
if its a wheel bearing going out, if you know which side its coming from jack that side of the car up to get the wheel off the ground. Once its in the air grab the tire at the top and bottom and see if it rocks a little. If so replace the hub. you can take it a step further and swap hubs from one side to the other, but the above is a good indicator in most cases
blackbyrd is online now   Reply With Quote
Old 03-20-2017, 10:40 PM   #6
M4N14C's Avatar
Yes do that first^^
There should be absolutely no play at all. Unless you're road racing or autocrossing, some replacement MOOG's or Timken's should be fine.
Old 03-21-2017, 08:26 AM   #7
AdsoYo's Avatar
Can't remember off the top of my head right now if the noise changes with car speed. I want to say it does but what I really need to do is find an empty large parking lot and have someone outside the car who can pinpoint where it's coming from. Sometimes I think it could even be coming from one of the rear wheels. Next dry day we have around here I'll test it.
Related Topics
Thread Thread Starter Forum Replies Last Post
creaking noise when turning steering wheel AdsoYo Suspension & Brakes 9 02-18-2016 10:23 PM
My shaft needed lubed LS BRAVADA Cadillac CTS-V 2004-2007 (Gen I) 5 06-18-2015 01:45 AM
Creaking rear suspension and rotational squeal Rob98LS1 Suspension & Brakes 9 04-09-2015 03:19 AM
97 Trans Am Front end clicking/snapping noise. (Not ball joints or Tie rod ends) reservoirdogs12 General Maintenance & Repairs 13 10-30-2011 07:39 PM
creaking caliper HawkFanatic Suspension & Brakes 6 03-30-2010 10:56 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
