Diagonal bar above panhard rod???
Just wanted to double check, my slp lm exhaust i modified a little to get my qtp y pipe to pull up a little, anyways, now the pipe that goes over the axle is hitting this stamped metal bar that is on a diagonal right above the panhard bar. I was told it does nothing and that i can remove it for the clearance i need to stop the banging. Everyone else think its ok to remove this bar? Dont even know what its called so if no one knows what i'm talkin about i can post pics tonight when i get home. It standds out pretty good though, its right above my panhard bar, which now is a hotchkis bar if it makes a difference. All thoughts are welcome. Thanks!
It is an upper panhard rod. It is actually a support for the PHB. It does "something" because I actually bent one on my 3rd gen. It is there to support the mount for the lower PHB. Many guys will tell you to remove it, but you do run the risk of breaking the mount for the PHB that it supports. Also, if GM could have saved the time and energy that they took to design, build, and install that bar, don't you think they would have?
I'd keep it.
I'd keep it.
Try taking a corner without your PHR installed - that's what it'll feel like when you break the PHR mount due to having removed the support bracket. Yes, there are people who have removed it. There are people who do all kinds of things. This piece (unlike the tunnel brace e.g.) has a VERY clearcut purpose and IMO you'd be sacrificing your safety driving on the street without it. Remove it at your own risk.
Copy & Paste Moderator
Originally Posted by 99CamaroSS
Thanks guys, i'm gonna stick w/ keeping it on then. I've heard sticking a piece of coolant hose in between the pipe and whatever its banging on will help. I guess thats my best bet??
If your exhaust its what banging against it, the hose will melt and smell bad in the process.
You can try it anyway and see how much of a problem it is.
Originally Posted by Ferocity02
You can get hose that doesnt melt. Someone did it with their banging y-pipe. Sounds like a good idea to me, as long and he gets the right type.
