Is an Adj. PHR Required for Lowered Cars?
Is an adjustable PHR needed when lowering the car or for alingment? I am wondering if I need to order one for when I lower the car. Thanks
[EDIT]: I think I found my answer (yes, it is required), or am I wrong....
It depends, some cases you may or may not. It def wont hurt to have it, ecspecially if your suspension mods change in the future. The reason for the Ad. PHB is to center the rear end under the car. Most of the time when a car is lowered the rear shifts to one side (mine was the driver side). The bar can be shortened or lengthen to correct this. Can also be helpful when running wider tires/slicks if there is clearance/rubbing issues.
iv lowerd mine with pro kit and chopped half a coil and still center as stock! if i were u i would lower it with the springs first then see how it looks before putting one in.
