bad vibrating after lowering the TA
i just lowered my car with the GC coil over kit. I still need to adjust the front cause its sitting at 24" and the rear is sitting at 26" im going to set the front at 26 as well. Now ive noticed when im in 6th gear and going 60 the car vibrates pretty bad wheni go faster it ends up going away. It doesnt do this when im in 4th going 40 or 50. Do you guys think id need to adjust the pinion angle? i was thinking i would need to rebalance the driveshaft but how often does a driveshaft unbalance itself?
If it does it at 60mph, regardless of which gear you're in, then it may be the driveshaft. If it only happens in 6th, then something in the trans is vibrating.
its only in 6th @60 but if i go higher than 80 it does it as well
have you check your pinion angle, the angle from tranny to drive shaft plus the angle from rear end to drive shaft will be 0 degree. (one # will be positive and other will be negative)
Originally Posted by Cal
My car is at 26/26, and there is only about 1.25 inches travel left. You must be right on the bump stops at 24"!
Im going to check the pinion but i dont have a pinion angle finder. I have the BMR adjustable tq arm
01red ws6- the kit isnt all that bad but i dont like how rough it is, i just took off the pro kit and it was kinda mushy but even though this is a 500/150 setup its a little responsive on bumps. It handles great on the turns though. Theres a Turn in SA that almost eveyone wrecks on and theres nothing but scrapes on the wall. The speed limit is 30 but i took it at 60 one night and i didnt have any dragging of the tires i actually stayed on the inner lane so it does turn a lot better than the prokit and better than the H&R springs
Originally Posted by 01 Red WS6
Does it bounce around alot? I have a friend with a civic and when he put his coil overs on it bounced like crazy. Is it too ruff, does it get annoying? I drive my car everyday so I dont want it to be uncomfortable
it does bounce but thats just the way some roads are. On the highway it rides fine. Its ruffer than the prokit but it handles a lot better. It gets annoying at first but you get used to it
01redws6- i used the bilsteins that i already had on the car. they were only on for about 30k per sam strano i didnt need to revalve them if i wasnt going to be driving the car at any autox or rr
Cal- ebay $200
Cal- ebay $200
