Lowered with Borlamouth/Loudmouth?
Old 07-27-2004, 11:33 AM
Z28Venom's Avatar
Default Lowered with Borlamouth/Loudmouth?
I'm not sure which forum this should be in Exhaust or Suspension.
I'd like to run the Eibach Pro-Kit springs, but I'm not sure if I'll have to change my exhaust.
Does anyone have either of these setups?
Old 07-27-2004, 02:52 PM
Bad Blu Formula's Avatar
I had that exhaust before and it doesn't matter what catback you have, you're still going to scrape.
Old 07-27-2004, 03:03 PM
RV
RV's Avatar
I have a dynomouth with those exact springs, and the exhaust never scrapes.
Old 07-27-2004, 03:10 PM
Fulton 1's Avatar
https://ls1tech.com/forums/generation-iii-external-engine/184016-who-here-has-true-duals-lowered.html
Scroll about halfway down and you'll see a ground clearance pic of my old Loudmouth setup with Prokit springs.
Old 07-27-2004, 03:20 PM
Z28Venom's Avatar
Originally Posted by Fulton 1
https://ls1tech.com/forums/showthread.php?t=184016
How much do you do/did you scrape with that setup.. I'm gonna have a XR-1 in place of the bullet.. A bit bigger.
Hopefully everything will be ok..
Old 07-27-2004, 04:03 PM
Fulton 1's Avatar
I scraped my 2.5", catted custom Y-pipe a lot more than the LM resonator, but I didn't use the car as a daily driver either, so I had the luxury of avoiding bad roads, speed bumps, etc. It's a tight fit, but IMO as long as you use caution going over bumps and such you'll be okay.
Old 07-28-2004, 07:53 AM
pylesm0311's Avatar
Default Dont worry!
I have the same set-up you are talking about, SLP Loudmouth and Eibach Pro Kit Springs. I have never scraped but take caution when driving over speed bumps!
Old 07-29-2004, 09:23 AM
01RedZ28's Avatar
I have the loudmouth and my resonator hangs pretty low. I'm always scraping it. You just have be careful driving on certain roads.
Old 07-29-2004, 09:53 PM
NVR_SPDS's Avatar
you just have to be careful.. my girls car has the loudmouth, and is on sportlines, which is more of a drop, than the pros.. it doesnt seem to rub, but were REALLY cautious anyway.
Old 07-30-2004, 11:13 AM
MyLilWS6's Avatar
I ran Sportlines with my LT's, ORY, and dynomouth setup. Never had a problem just had to stay away from huge speed bumps. Now I'm Hooker and love it.
