Do I need realigned after shock swap?
Old 07-30-2004, 07:28 PM
theblur98ss's Avatar
Default Do I need realigned after shock swap?
I just swapped out my hal shocks for a set of hal R serier shocks. Now the car seems like it wants to swerv and sway back and forth. Would the shocks mess something up? I set the ride height about a half a spring seat higher with the new ones.
Old 07-31-2004, 02:57 PM
BADz2ATE's Avatar
did you swap the shocks only or did you adjust the ride height too? from what i understand it sounds like you adjusted the ride height. if you did, then have it realigned.
Mike
Old 07-31-2004, 04:24 PM
ZaneO's Avatar
Should probably get it realigned.
