cant get rear caliper piston to compress
well i tried to put some new rear pads on and the piston woulding compress. opened the bleeder and still nothing. i heard i need to get some sort of tool to compress it. how do you guys get yoru rear brake piston compressed?
This thread is a little old but I'm a little confused.
Do you need a special tool to assist in compressing the rear calipers or not? The write-up on installuniversity.com doesn't mention anything.
nope mine was just hung up, when i took the caliper off the car and hit it with a hammer a little bit, it went right in. or u can put a screw driver in the center and put all your weight on it
Copy & Paste Moderator
Use the old pad and a c-clamp.
The screw in method is for cars with the parking brake (e-brake) integrated into the caliper. LS1 4th gen f-bodies have a separate parking brake mechanism that is a drum on the inside of the hat of the rear disks.
The screw in method is for cars with the parking brake (e-brake) integrated into the caliper. 4th gen f-bodies have a separate parking brake mechanism that is a drum on the inside of the hat of the rear disks.
LS1 4th gens have that. LT1's do not, they screw in.
The screw in kind is such a PITA. My mother's old 1990 Lumina had them. There was a trick to get them to compress. You couldn't just screw them in. After a couple turns, you'd get no progress and have to back up a bit to continue on. You also had to push while you turned. I also used needle nosed pliers which meant that I slipped alot. I didn't see the tool until after we got rid of the car...oh well.
OK, I corrected my post.
I just didn't wnat anyone to try to crush an LT1 caliper.
I bought the tool (it's a press/rotator) for my VW GTI that I had, but it works on most of them and has been quite handy. It's not cheap though.
This is the one, it's overkill for our cars, but VW's and many others require you to spin and compress the piston at once.
http://www.lislecorp.com/tool_detail.cfm?detail=270
