Another Stuck Rotor Thread
Old 08-15-2004, 03:59 PM
Razzak's Avatar
Default Another Stuck Rotor Thread
First, here covers most of the solutions I've found:
https://ls1tech.com/forums/showthrea...ht=stuck+rotor
Tried the rubber mallet, tried WD40 and some oils. It appears really stuck to the center hub. Nothing stuck on the bolts. What's the next level? Me and a friend tried pulling the rotor at the same time, and no go.
Old 08-15-2004, 04:05 PM
Blown Ta's Avatar
i got under the car hit it with a hammer 3 times then spin the rotor and hit it three more times and out it came
make sure the emergency brake is all the way down
hope this helps
Old 08-15-2004, 10:53 PM
trackbird's Avatar
I had one stuck on my Camaro. I went to sears and bought a 3 lb hammer. On the third whack (just let it have it) on the disk face (not by the studs, hit the surface where the brake pads run) it "fell" off and hit the floor. I only recommend this if you are replacing the rotors. If you intend to reuse them, have someone hold a 2x4 up there and hit that with a 3 lb hammer (to avoid denting the steel surface).
Have fun!
Old 08-16-2004, 12:23 AM
Cal
Cal's Avatar
I have a large three-jaw puller that so far has removed every stubborn drum or rotor I've ever come across. I think I got it at Pep Boys but not absolutely sure. Adding some heat with a torch will help it to expand and come off easier also.
Old 08-17-2004, 01:12 AM
roy
roy's Avatar
Isn't tthere a threaded hole on the rotor that you put a bolt in and force the rotor from the hub.? Ic don't know myself since I don't run the stock system anymore.
Old 08-17-2004, 05:27 AM
LS1MONSTER's Avatar
I just changed my pads and rotors not long ago for the first time. 63,000 miles to be exact. The fronts came off fairly easy. The rears were on there pretty good. But a good couple of hard shots with the hammer took care of those bastards. Don't be afraid to give them a good hit.
Old 08-17-2004, 07:58 AM
trackbird's Avatar
My Mazda had that, but I don't remember seeing it on my Camaro. However, my stock rotors are long gone.....
Quick Reply: Another Stuck Rotor Thread
