C5 Upgrade: Rear rotor/caliper, front bolts (not in search)>>
Old 08-17-2004, 02:22 PM
SilverSmoke's Avatar
Default C5 Upgrade: Rear rotor/caliper, front bolts (not in search)>>
Couldn't find any real clear answers in the search mode of this site. Final questions for brake upgrade:
Fronts Using C5 caliper and rotor:
1) Do I use stock F-Body Hardware, bolts, etc?
2) Do I use F-Body pads, or can I use C5's safely?
Rears:
1) Can I use C5 rotors with stock F-bod calipers?
1a) if yes to 1, can I use C5 pads as well?
2) Can I use C5 caliper and rotor?
2a) Any hardware needed, special bolts (C5), pads etc?
2b) Can I use C5 pads?
Everything I read, and after talking to LG, Front Caliper and Rotor can be C5. Must use F-body pad on front though. For the rears, cannot fit the C5 caliper and rotor. Should keep as stock, and use f-body pads.
Can someone please help answer some of these questions. I have the bracket on order, and SS lines, need to know what else I should get.
Thanks!!!
Old 08-17-2004, 03:35 PM
NOBR8KSS's Avatar
Personally, if I was upgrading to the Corvette brakes, this is what I would use:
Front:
Corvette calipers, caliper relocation brackets, Corvette rotors, and Corvette pads. The caliper relocation brackets should come with new bolts, reuse the other F-body bolts.
Rear:
Leave it stock....the Corvette rear brakes are nearly identical to the F-body setup.
Old 08-17-2004, 03:39 PM
Front:
Rear:
Can vette pads be used up front with vette rotor/calipers. I heard we cannot b/c fitment issues.
Old 08-17-2004, 03:47 PM
mitchntx's Avatar
If you use the F-Body abutment brackets, no ... you have to use F-Body pads.
The C5's pad shape will interfere with the abutment bracket, I believe. The F-Body pad has more of an arc ...
Old 08-17-2004, 04:10 PM
Can the abutment bracket from the C5 fit? If so, this would in theory solve the fitment issue with the C5 brake pad?
does everything else sound correct above?
Quick Reply: C5 Upgrade: Rear rotor/caliper, front bolts (not in search)>>
