What are the tell-tale signs of a bad brake booster?
Old 09-04-2004, 04:40 PM
MeanWS6's Avatar
Default What are the tell-tale signs of a bad brake booster?
Will the brakes still work properly with a bad booster?
Old 09-04-2004, 06:59 PM
felton316's Avatar
Bad brake booster, will make for a really stiff pedal. Yes, they will work, properly?? It would be as if you were running non-powered brakes.
Old 09-04-2004, 11:43 PM
Midnight F-117A's Avatar
also inconsient brake pedel feel at every braking attempt.
Old 09-05-2004, 11:38 PM
Powered By V8's Avatar
also, i believe its an old trick to turn the car off and pump the brake pedal and see if it holds the pressure.
Quick Reply: What are the tell-tale signs of a bad brake booster?
