Qa1 springs yay or nay
i will be doing front qa1 shocks and was wondering if i should use their springs. I have read that they are a bit soft and there is little adjustment to the ride height since they are so soft. Was thinking of using my stock springs. What do i need to do to make them fit. Seen that bmr has spring perches for them, do you guys use them or use something else... what other springs from qa1 could we use. Keep in mind im looking for more weight transfer rather than twisties, i drive on the street if that matters any...
I have them and there is actually a good amount of height adjustment. I have mine set at about 1in lower than stock. I can still raise it about 1.5-2in or drop it as low as I want. I have the shocks set to the third click(1st being the most loose) and my front end pops up nice. Sway bar removal is the only weight reduction in the front of my car.
