Why am I hearing squeeks coming from my rear suspension?
Old 10-08-2004, 09:49 PM
damon_Z's Avatar
Default Why am I hearing squeeks coming from my rear suspension?
I have a 2002 Z28 with a bone-stock suspension and 44,000 miles. Lately, I've noticed squeeks coming from my rear suspension when I slowly accelerate from 0-30 mph. What could those squeeks be and how do I eliminate them? Thanks in advance for the info.
Old 10-09-2004, 12:10 PM
TD's z's Avatar
if its any thing like my car was it's annoying as hell i replaced my rear shocks and that cured it
Old 10-09-2004, 03:04 PM
Full-Force's Avatar
i would replace every bushing in the rear with poly ... you can get the whole kit and they are cheap
Old 10-09-2004, 04:43 PM
Moderator
jimmyblue's Avatar
Sway bar bushings, sway bar end links and
Panhard mount bushings have been my main
squeakers so far.
Old 10-09-2004, 06:08 PM
damon_Z's Avatar
I just got done soaking the suspension with a can of WD-40, but it really didn't do anything. I think it's time to finally start modding the car.
Old 10-09-2004, 07:55 PM
damon_Z's Avatar
I'll take that back. After taking out my rear-driver's side wheel and spraying the bearing, brake rotor, panhard rod bushing, and control arm bushings with WD-40, the squeeks disappeared.
Old 10-09-2004, 10:18 PM
Racehead's Avatar
'Cuz your exhaust is too quiet
Old 10-09-2004, 10:28 PM
jmil1974's Avatar
Don't use WD40, temp fix - it's not really a lubricant. Use a spray silicone or lithium lube for suspension stuff.
Old 10-10-2004, 08:57 AM
Viper's Avatar
NAPA sells a graphite spray lube ( not cheap, $9 or so ) for rod ends if you ever go that route.
Old 09-11-2005, 11:54 AM
damon_Z's Avatar
The squeeks were actually coming from the rear brake pads. I think they were the Quiet Stop brake pads from Pep Boys. I replaced them with an OEM rear brake kit from a GM dealership and that solved the problem.
