Strange vibration
Strange vibration
I have the Pro-Kit, subframes, BMR adj. Panhard, BMR LCA's with poly bushings.Recently, when I take off normally from a stop, I feel and hear a strong vibration from around the area of my rear drivers side tire. It stops at like 1500 rpm and sounds normal again. If I rev it high and take it off kind of hard, I dont hear anything. I am thinking it is the LCA's, I greased them recently because one was squeaking, any other ideas why they'd be doing that? Any help appreciated. Thanks.
nevermind, checked and my drivers side LCA was VERY loose. That just tells you that after you buy a car thats modded you should go through and check everything yourself.
