loud squeek whenever i break
wheneever i break there is a loud squeek what could that be a got my breks checked friday and the guy said the breaks were fine any help
IMO the little stainless steel clips vibrate and make the brakes squeak. Put some of the blue or orange brake-quiet on the little stainles clips where you slip them into the calipers, then put the pad into the little clips.
After removing my front brake pads, I found a tiny lose rock in the driver side brake pads and this is what was making a very loud noise when I applied the brakes, the lose rock just feel freely as I took the brake pads off, I would take the brake pads off to check for rocks in the pads if the mechanic only did a visual check.
