how low are u guys riding?
Old 11-12-2004, 06:22 PM
scifone's Avatar
Default how low are u guys riding?
the slp subframe connectors on my 98 camaro with hotchkiss 2" drop springs is only about 3.5" from the ground. im wondering if anybody else is this low...
Old 11-12-2004, 06:33 PM
nikejr16's Avatar
Im pretty low I got the sportlines w/ slp sfc's. I dont know how low exactly, but its low.
With my stock wheels I sit low, but w/ my corvette 17's front and 18's rear its a little better, but not much better.
Old 11-13-2004, 06:58 PM
amit's Avatar
i have suspension technique speed tech springs.
pic in sig..
Old 11-14-2004, 03:34 AM
ZR2877's Avatar
Mine is lowered 1.5" and with True Duals there is not much clearance. I actually got pulled over for it the other day. He said I didn't have enough clearance. A while back I was lowered 2" and was low but I had stock exhaust. SO if you have True Duals I wouldn't recommend 2" unless you can tuck them way up close but then you might have to put up with banging the floorboard. Just My $.02
(Edit) So if you are stock exhaust 2 " is fine. If going with TD like it says you plan to purchase in your sig I would go back to 1.5". The exhaust will still be low but you can get by. I only scrub on some speed bumps.
Old 11-14-2004, 03:40 AM
ZR2877's Avatar
If you go to the External Engine section there are some great pics of a car with True Dual that area extremely low. I can't recall if the car is lowered but I think it is. I love My Kook's LT with True Duals. I haven't heard a better combo. I can't wait till I get a Cam then they will sound even better.
Old 11-14-2004, 01:49 PM
Cefiro's Avatar
Im pretty low, and going to install true duals. I dont think I will have any ground clearence after the install.
Old 11-14-2004, 09:39 PM
scifone's Avatar
where would the most problematic area on the true dual exhaust be?
Old 11-15-2004, 11:44 AM
Cal
Cal's Avatar
I have slp sfc's and my car is lowered 2 inches (26" to fender lips.) There isn't much clearance, but I have had few problems. I'm just careful and avoid the areas I know will cause it to hit.
Quick Reply: how low are u guys riding?
