Quick Sway Bar Question
My '94 Z28 has the FE2 suspension RPO. What size is my stock rear sway bar? Local Chevy dealer couldn't tell me.
I am at work and the car is at home and I want to let a buddy know today if I will buy his 1LE rear sway bar (which is 21mm).
Thanks in advance!
Todd
Thanks in advance!
Todd
LS1TECH Sponsor
21's are generically knows as "1LE's" even though it's not always the case. It likely is the 21 but all you have to do is measure it.
But, if you have a stock front bar on your '94, (30mm) adding this one in the back is not at all wise. And I still won't use it with a 32mm bar either (the 1 1LE that had a 32/21 combo also had 70 lb stiffer front springs in combination with regular Z28 rear springs). If you go 32/21, or worse yet 30/21 with stock springs, or heavier springs all around vs. just stiffer in front, you are just making the car looser in the back. Harder to drive fast and less stable.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
The car is a drag car. Hasn't had a front sway bar at all for years. It also has V6 coils in back to take the weight transfer. I want a stiffer rear sway bar to keep the rear tires more evenly planted during a hard launch.
Then just buy the 25mm from suspension techniques. I am not a fan of the no front bar setup on a car that's driven at all, it can cause stability issues, but the 25mm will work hard to keep you "square" on the launch....
http://www.bmrfabrication.com/XtremeDuty.htm
Originally Posted by TooSlow02
BMR makes a rear sway bar specifically for drag cars. It's a 32mm solid bar, with 5/8" adjustable rod-end style endlinks (to preload the bar), brackets, and hardware.
I have the ST rear bar on my '99 already. I appreciate everyone's advice, but I was asking specifically about the 1LE bar because that is exactly what my friend has for sale for a reasonable price.
