My autozone rotors
Old 04-27-2005, 08:01 PM
DONAIMIAN's Avatar
Default My autozone rotors
Just thought id show what my autozone rotors look like, and no, theyre not warped one bit.
and yes in that last one that is purple that you see, they were blue, but changed colors. The only reason im replacing them is becasue of the cracks thats forming. That goes to show that you can get a cheap rotor, and not have to worry about warping em.
Old 04-27-2005, 09:00 PM
Copy & Paste Moderator
VIP1's Avatar
Looks like they have been over-heated. They should not be blue/purple or cracked.
Old 04-27-2005, 09:01 PM
Midnight F-117A's Avatar
I had the exact same problem you're having, I used Hawk HP+ pads on those rotors.
That was until I got a deal on Eradispeed for the fronts which I am still running now with no problems.
Old 04-27-2005, 09:02 PM
BrandonSS's Avatar
You sure the caliper isnt frozen? That looks like it has gotten way to hot.
Old 04-27-2005, 11:16 PM
Slammed-am's Avatar
How much were they, Donay?
Old 04-27-2005, 11:32 PM
DONAIMIAN's Avatar
~25 bux each
Old 04-27-2005, 11:59 PM
Slammed-am's Avatar
Not bad...
Old 04-28-2005, 07:33 AM
Ojustracing's Avatar
That what my rotors look like after a weekend of road racing. Ac-delco durastop rotors can be had for under 20 bucks. John
Old 04-28-2005, 11:27 AM
Bad Blu Formula's Avatar
Better tell those bad boys to take a hike.
Old 04-28-2005, 01:36 PM
ponyeater01LS1's Avatar
no way u picked up dura stops for 20 buck apiece i just called a friend who works at chevy dealership in parts and I got the buddie hook up price for 70 dollar a rotor $157 for 2 rotors and ceramic pads. sombodies pullin ur leg on 20 bucks..
Old 04-28-2005, 03:33 PM
Pony sorry I was refering to C-5 rotors. My bad.
But the funny thing is that C-5 rotors which are bigger and better are only $18.40 in Dura-stop. 88925547/88925548 Go figure!!!!
John
Old 04-28-2005, 04:03 PM
ROCNDAV's Avatar
John
How big are C5 rotors, and can they (or calipers) be mofdified to work on Fbodeis? I heard of someone using Z06 brakes on an F body.
D
Old 04-28-2005, 06:04 PM
stoker420's Avatar
I have autozone's also however, mine was set up in a cnc and drilled and slotted so I don't have no heat problem many hard stops and still feel and stop awsome.
Old 04-28-2005, 08:02 PM
D
The c-5 rotors are 1" +- bigger than. To run c-5/z06 rotors and calipers you need a adapter bracket and some other items. Current company's that have brackets are LG motorsports, Umi performance and I use a bracket that is not made anymore(Bob Bishop) This bracket is designed correctly!! I run the c-5 rotors and Z06 calipers..
I suggest going to FRRAX.Com and lurk around the Brake section.
One quick note drilled rotors are very prone to cracking in high heat applications (Auto Cross/Road Racing). Most people that race dont use drilled rotors. For the BLING/BLING factor go for it. Anything else go solid.
John
Old 04-28-2005, 09:09 PM
VIP1's Avatar
Double negative....so you do have a heat problem? (j/k)
BTW, Cross-Drilling and Slotting on today's braking systems are pretty much just for looks.
Here is some more info on rotors and pads:
https://ls1tech.com/forums/suspension-brakes/262940-replacing-rotors-what-get.html
(Just dont do what absolut_speed said, he was joking.)
Old 04-28-2005, 10:31 PM
ROCNDAV's Avatar
What about turning the rotors? I've often wondered if shop will refuse or charge more due to driller and/or slotted rotors. Anyone have any first hand knowledge?
David
Old 04-29-2005, 02:37 AM
DONAIMIAN's Avatar
David
For what thoes rotors cost, its not worth the trouble pulling em off just to get the turned, just so theyll look the same in the next 3 weeks of street driving.
Quick Reply: My autozone rotors
