UMI lca's review and questions
UMI makes very nice lca's. I bought the non-adj in red they look beautiful and fit great. They fixed a squeak my front bushing on my driver side lca was making. This squeak sounded like a bird was being tortured behind my car.
My question is now that other things can be heard since the squeak is gone should these lca's be more clunky then the stock ones? Also what else can rattle and clunk from the rear?
thanks
thanks
MY UMI'S ARE GREAT!!!!!!!!!!!!!!!
The only thing that really grabbed my attention is how well I can feel the transmission shift.
Theres another comment from me that no ones ever heard before.
Originally Posted by jxaxsxoxn
No.
Thats a long list there.
i did some searching, i think i need to tighten the bolts more
btw i also noticed they cured my minor wheel hop at the top of first
thanks
thanks
Ryan (UMI) seems to make a great product and take good care of you.
Yes, you can overgrease them. You don't want to buldge the bushings with the grease gun (if you put too much in, the sides will swell and begin to get pushed out of position). I'd just use a few squeezes of the grease gun on each side and you should be fine.
some more questions...
how much grease should I put in them? can I over grease them?
thanks
thanks
well i am not a 10 sec guy but i have tested them at the track. I had the bad z lca's and they rattled like **** and i am glad i dont have to put up with that **** anymore, but i was cutting 60's in the 1.8 range w/ them and now im in the 1.9 range. i cant launch my car or my rear will go boom but i have a 12 bolt coming. i do like the umi lca's but they dont hook up as good as the ones i had.
Silverbeast- I am glad to hear you like the set-up you have from us. I remember when you had placed your order, it was in the early stages of when we just sponsored this site. I remember your complaints on noise and I think it was your wife that didn't want to ride in the car anymore.
The reason you are seeing a slight traction loss now is before you had a rod end/rod end (Solid bushing/Solid Bushing) set up. Now what you have is a polyurethane busing/Rod end set. The polyurethane bushing will deflect or give more then a solid bushing will. Now the benefit of that control arm is you now have your ride quality back and your wife is happy
Regards,
Ryan
Regards,
Ryan
Originally Posted by Carbed4thGen
So the rod end/rod end setup hooks up better?
thanks
thanks
awesome, i just installed some along with cam 4.10s and other goodies in my sig.. there really really great actually!
