ABS delete and safety inspection
Old 03-13-2006, 09:30 PM
The Sad's Avatar
Default ABS delete and safety inspection
If I delete my ABS (using ABS delete kit) will my ABS Inop light be on? Will my car fail safety inspection if the ABS doesn't work?
TIA
Old 03-14-2006, 02:27 AM
DONAIMIAN's Avatar
Ive passed with the light on twice.
Old 03-14-2006, 06:30 AM
blue01ta's Avatar
The ABS light will stay on. I just took the light out of mine. It's not that hard.
Old 03-14-2006, 09:16 PM
The Sad's Avatar
So it will pass the OBDII test with the ABS having problems (or disabled)?
Old 03-14-2006, 09:27 PM
sills1's Avatar
Did you remove ABS for a weight savings or something else?
Old 03-14-2006, 10:57 PM
2K2WS6TA's Avatar
The OBD2 test just checks the powertrain control module (PCM) for emissions related codes, it couldn't care less about the abs light, that has nothing to do with the emissions control equipment.
Now whether or not the safety guy lets it pass, I would think that it wouldn't matter, lots of cars don't have ABS, and as long as the brakes still work, they shouldn't have a problem, you might call around and ask if having an ABS light on is an automatic failure
Old 03-14-2006, 11:53 PM
The Sad's Avatar
I am going to remove it to save weight and put different diameter tires on front vs. rear.
Good idea 2K2WS6TA.
Old 03-15-2006, 12:28 AM
TINKRD's Avatar
i've passed for 4 years with the ABS INOP light on.
I just now got around to taking the bulb out of the cluster.
Old 03-15-2006, 03:14 PM
The Sad's Avatar
I called a place today. They said it won't fail with the light on, just get an "advise".
Quick Reply: ABS delete and safety inspection
