Which autozone rotors?
Old 03-20-2006, 04:30 PM
Syxx613's Avatar
Default Which autozone rotors?
hey guys, i have heard that the autozone rotors are good but which ones? the duralast or the valucraft? thanks guys!
Old 03-20-2006, 04:37 PM
radz's Avatar
might want to check out rotoworks from ws6store.com I figured what the hell their cheap so if they warp ill buy diff one. I've put them through some hard stops 100+mph and there fine, I've only had em for 2k miles though
Old 03-20-2006, 04:41 PM
99zman's Avatar
hows the zinc coating holding up on them??? i havent installed mine yet??
Old 03-20-2006, 04:44 PM
OneMeanZ's Avatar
I think it's the Duralast ones
Old 03-20-2006, 05:00 PM
jerflash's Avatar
get the autozone duralast ones....and dont look back
they are the best rotors out there for regular daily driving
i would love to get some baer rotors but they are really expensive
they dont warp easy at all and are cheap
Old 03-20-2006, 06:01 PM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
Why don't you get some Brembo blanks?
Old 03-21-2006, 10:57 AM
VipZ28's Avatar
This man speaks the truth. I've had mine on there for about 2 years (it's a weekend only car) or about 10,000 miles and a dozen autocrosses... no warping yet!
Old 03-21-2006, 11:51 AM
ls1mongrel's Avatar
Duralast all the way !
Old 03-21-2006, 12:35 PM
JD_AMG's Avatar
I have duralast as well, huge improvement over stock and they're cheap too.
Old 03-21-2006, 12:47 PM
tt2000z28's Avatar
all I can say is that after buying any kragen or autozone rotor one should check it first to make sure it does not need to be turned. Then if its nice and true, install them and pray you dont over heat them. They are cheap because they are made of checp metal.
Some cheap rotors are cheap because they are not perfectly flat when you buy them.
The dude from kragen told me he has many return customers with there rotors that need to be turned some because they are just that "cheap rotors"..and were never turned perfectly flat to begin with...
Old 03-21-2006, 01:53 PM
2 SSlow's Avatar
i work at autozone, Duralast, and Duralast Gold are the ones you need to look at. i refuse to put any "Valucraft" part on my car.
Old 03-21-2006, 09:32 PM
Keysplayr's Avatar
??????? Heh? The Duralast rotors are actually better than factory GM rotors.
I had to change all four corners at under 20,000 miles because of warpage. Switched to Duralasts, and 50,000 miles later approaching 70K, Brake pedal is smooth as glass. So, there doesn't seem to be anything cheap about them except the price. You don't always have to spend huge amounts of cash for good auto parts.
Old 03-21-2006, 10:31 PM
2000BLKSupersport's Avatar
all autozone rotors suck go with brembo blanks! sorry IMO. and WS6 cross drilled and slotted.
Old 03-21-2006, 10:35 PM
blazinws6kush's Avatar
I got my Baer Decelarotors from Autozone. The only rotors i would buy from there. They were about $220 with my friend's employee discount.
Old 03-24-2006, 04:32 PM
Keysplayr's Avatar
OMG!! It's as if you guys like to get your wallets Pwned.
$72.00 for both front rotors and on my second set of brake pads on these rotors. Don't be a sap and splurge for a marketing gimmick. No offense intended bro, but 220.00 for rotors is the same as getting mugged at gunpoint in N.Y.C.
Be smart with your money and it will take you further.
Old 03-26-2006, 11:15 AM
redsscamaro's Avatar
duralast!!!!
Old 04-04-2006, 11:24 PM
Mooobunnny's Avatar
Duralasts.....much better than drilled/slotted rotors IMO
Old 04-04-2006, 11:34 PM
steele's Avatar
Yet another vote for Duralast. Have them on two cars now and love 'em.
Old 04-05-2006, 12:18 AM
Foxxtron's Avatar
You can't go wrong with brembo blanks or duralast rotors. before I upgraded to my current BBK, brembo blanks are what I used for about 70K or hard AXing.
Now, you can definitely go wrong with drilling/slotting/dimpling the rotor face, because they don't offer any better bite, nor better cooling. Better bite is offered with a more agressive pad compound and cooling is achieved with the cooling vanes in the rotor.
Quick Reply: Which autozone rotors?
