drag brakes?
Old 10-16-2007, 04:29 AM
dkbmxer002's Avatar
Default drag brakes?
i was wondering what brakes you guys with the 15x10 welds are running? i have looked into some drag brakes but they appear to be a grand a wheel..... what setup are you guys running?
Old 10-16-2007, 04:22 PM
stevensLS1's Avatar
you can run stockers and grind down the rear calipers and that will work. or buy strange or aerospace brakes.
Old 10-16-2007, 07:09 PM
dkbmxer002's Avatar
yea i have the stockers ground down i just don't really feel it is a safe situation. what is a good place to buy the aerospace or the strange?
Old 10-16-2007, 07:17 PM
LS1TECH Sponsor
ALLBOTTLE's Avatar
What brakes are you looking at?
Aerospace will run you about 1200 for all 4 corners
Strange will be around 1800 and are just a bit lighter.
Old 10-16-2007, 07:19 PM
Phoenix 5.7's Avatar
i would trust stock brakes over drag brakes. and drag brakes are strictly track
Old 10-16-2007, 07:23 PM
dkbmxer002's Avatar
i'm looking for just the rears.
how bad are the drag brakes for the street?
Old 10-16-2007, 07:59 PM
2002_Z28_Six_Speed's Avatar
True.
They would never make it in an OEM application. They are for a car that isn't going to make it more than a couple miles without an inspection.
Old 10-17-2007, 05:00 AM
stevensLS1's Avatar
give steven at SJM at shout im sure he can answer all your questions about strange since he sells them.--------->>>
Old 10-18-2007, 02:23 AM
El_Diablo's Avatar
I feel the same way man. I actually had to grind down the area where the bolt goes through the backing plate into the caliper. I'm scared to drive down the street, muchless bring it to a stop on the drag strip. I think in certain cases that required extreme carnage to the stock calipers, rear drag brakes are the safer bet.
