Torque Arm Vibration
Old 11-16-2001, 10:40 AM
Quick Time's Avatar
Default Torque Arm Vibration
Just put the Spohn TQ Arm in and its a nice piece. Got the chromemoly race version. How much noise and vibration is expected. Since it does mount up to the floor boad and has no rubber to insulated the sound. It seems my y pipe hits the cross memeber at idle at times. Its the ruff idle that i beleive that causes it. Driveshaft angle is +3 and rear is -5 degrees so thats -2 degress which should be fine for street and -4 to -6 for the track. Comments please.
Old 11-16-2001, 05:49 PM
LS1 Tech Administrator
Patrick G's Avatar
Default Re: Torque Arm Vibration
You want 2 degrees nose down on the pinion angle in relation to the driveshaft. If the drive shaft is +3 degrees and the pinion is -5 degrees, the relative pinion angle is 8 degrees nose down and very high vibration and u-joint wear will occur. Make sure you're doing your math right.
The pinion angle should be +1 degree for the you to have a 2 degree "nose down" attitude when coupled with a +3 degree driveshaft.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 11-16-2001, 07:29 PM
Tire Smoking Tranny Blowing Director
Cool28's Avatar
ok you lost me. I thought it was pinion minus driveshaft or something.
Old 11-16-2001, 07:52 PM
TR
TR's Avatar
I'm having the same "fun" trying to get my BMR torque arm dialed in.
It's a real PITA trying to change the angles while laying on the garage floor (to keep the car level while doing the adjusting). I need to find a place that has a pit I can use...
Old 11-16-2001, 08:58 PM
Quick Time's Avatar
From what i read on the spohn instructions is subtract the pinion angle from the driveshaft angle. I thought that if my pnion angle was -5 and my ds was +3 then the true angle would be -2 degrees. I might be wrong on how to do the math on this subract a negative from a negative equals a positive or something like that. So what should my pinion angle and driveshaft angle be for -2 degrees.
I think my vibration is from the y pipe vibrating on my cross member.
Old 11-17-2001, 10:03 PM
2000 Camaro SS's Avatar
I have the same setup as you. A lot of the vibration can be from the Y pipe hitting the arm. It happened to me and was very bad. I moved the Y pipe over some and I hade to loosen up the rest of the exhaust and rearranged it. I even took the bracket that holds the Y pipe off re-drilled the mounting holes so the exhaust was farther away from the arm. The other problem is from you having to much pinion angle. 2 to 3 at the most. Remember it is a preload on the rear end and is in reality putting a torque on the drive shaft.
Quick Reply: Torque Arm Vibration
