Wilwood rear brakes & C-Clip Eliminators please help.
Old 04-28-2002, 09:16 AM
2000 Camaro SS's Avatar
Default Wilwood rear brakes & C-Clip Eliminators please help.
What did you have to do to make your Wilwood rear brakes work with C-Clip elims? The photo in the instructions does not look at all like my set up. Summit & Wilwood insist I have the right set. Any one can help I really need it. The question, did it go right together? Did you have to modify anything? Who's C-clip Elims are you using? Is the bearing straight or tapered? That is the most important question.
<small>[ April 28, 2002, 09:23 AM: Message edited by: 2000 Camaro SS ]</small>
Old 04-28-2002, 08:05 PM
Steve1969LS1's Avatar
Default Re: Wilwood rear brakes & C-Clip Eliminators please help.
Do you have ASR? (tracktion control)?????
Old 04-28-2002, 08:09 PM
No ASR or ABS gave them up.
Old 04-29-2002, 08:06 PM
Got it figured out. Friggin Wilwood gave me the wrong part number. They gave me the one for a rear with C-clips. Get this Summit says the part (Brakes)is the same for C-clips or with out. Because the c-clip are inside of the rear end and not even near the brakes. Fuggin idiots!
Quick Reply: Wilwood rear brakes & C-Clip Eliminators please help.
