SLP Level 1 Suspenios Setup Any Good?
Re: SLP Level 1 Suspenios Setup Any Good?
I have had the Level 1 on my car for the past 20K miles. For a daily driver it is great, and handles much better than the stock springs/Decarbons. It works very well on the autox course as well. I am replacing the Bilsteins with Koni's as I want adjustable shocks, and the springs with a Pro-kit because I want it lower for more negative camber up front. I plan to sell the shocks, but I am keeping the SLP Eibach's as I will probably swap back to them after the autox season is over.
Don't bother with the boxed arms; the boxing is fine but the poly bushings they use bind up, squeak and are generally not a good idea for LCA's. The 1LE stuff is fine for hard street use.
Thanks 1le. I guess the squeaks and rattles are nothing that a yearly spring greasing couldn't take care of. Should I get teh reenforced lcas and phr, or just stick with the basic setup?
Bear,
Go to SLPENG.com and go to the firehawk section. There is a post there of a guy who was doing 160 mph runs and turning while decelerating to 150 w/a firehawk with the SLP level 1 added and a stock WS6. The firehawk was hands down the winner in the handling department! Sounds like a very god set-up. Also, check ttperformance.com and hpaparts.com for the cheapest prices on this. i will be buying this soon along with Global west SFC's.
I'm with u JC! That is y I asked. I saw the price for this on HPA and TT Perfom and I want this. The problem is that there is NO rear sway in the package, and the front 32mm sway that it comes with, I already have on the SS. This is NOT the SAME package that u order when u do it OE. So the question is do I order EVERYTHING seperate with the 35mm front or do I suck it up and have an xtra front sway bar in 32mm. I will have to call Troy,MI and find out how much the OE package is with BOTH the 35mm front AND the 21MM rear. Does anyone want to buy a front 32mm sway bar for $50 shiped. Let me know <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Hey guys, my wife has an 02'base SS with no options. The car is good but the nose dive and the body roll leaves something to be desired. I am looking at the SLp Lev 1 kit and it has the Bilst., Eibachs, F sway and rear lca's, and a PHR. I am also going to add DD SFC's as well. The package price is hard to beat. I want to use this car at local auto cross stuff nothing really big, and my wife drives the car 90 miles a day on the hgwy back and forth to work. Is the package worth it? Will it be a NOTICABLE difference? Any input or help would be appreciated. Thanks Bear
