Right rear is 1/4 higher than left!?!?!?!
Old 03-22-2003, 10:47 AM
John02SS's Avatar
Default Right rear is 1/4 higher than left!?!?!?!
The right rear on my car is a little less than 1/4 higher after the BMR spring install. I have centered the rear with a APHR and the right is still higher. Not very much, but I'm really really really ****! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> Just wanted to see if anyone had any suggestions on leveling it out. Or at least tell me yours is the same way so it won't bother me as bad. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> I've checked all the spring seats and everything is correct. Thanks in advance.
John
Old 03-23-2003, 11:13 AM
John02SS's Avatar
Default Re: Right rear is 1/4 higher than left!?!?!?!
Thought I'd get alittle more response.....nothing?
Old 03-23-2003, 02:00 PM
trackbird's Avatar
John,
Drop the rear springs out and swap them with the opposite side, that will tell you if the car is bent, if the springs are wrong, or if it is just an illusion. Start with that test and let us know what you find out.
Old 03-23-2003, 03:35 PM
FstBlkz28's Avatar
my car sat kind of like that a few days after i put the g2's on. I took it out for a drive and it leveled itself out.
Old 03-23-2003, 04:20 PM
John02SS's Avatar
Thanks guys! I made sure the springs were sitting the same way on the rear end and adjusted them some. I will see tommorrow if it made a difference as I found a nail in my tire so I just left it off and will get it patched tommorrow.
Quick Reply: Right rear is 1/4 higher than left!?!?!?!
