Did i toast my hub/bearing? - LS1TECH
Thread Tools Search this Thread
Old 08-05-2006, 04:45 PM   #1
pHEnomIC's Avatar
Default Did i toast my hub/bearing?
I had to change my steering knuckle for something on my z/28.
The hub/bearing was seized on very tightly. I whacked it with a hammer on the back a couple times and the sides to get it out. I didnt hit the actualy rotating assembly but i did hit the housing. Now, when i turn the hub, the thing sticks in position. It won't freely rotate anymore. Did i destroy the thing? I would hate to have to buy another.
Anything I can do? Should i try to mount it on the new knuckle and see what happens or should i just get a new one?
pHEnomIC is offline   Reply With Quote
Old 08-05-2006, 04:57 PM   #2
TA TECH's Avatar
What are you doingreplacing or puting on a differentpart if you have a bearing assybly that won't turn freely you probably need a new one!
TA TECH is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Rear axle bearing/hub replacement jaxcam02 Gears & Axles 9 03-01-2016 12:43 PM
TCS and ABS inop question HerHawk Pontiac Firebird 1967-2002 8 09-18-2015 11:47 AM
Please HELP :( D3VIL Suspension & Brakes 15 03-10-2014 09:09 PM
Hub/Bearing Assembly lastcall190 General Maintenance & Repairs 5 12-04-2013 05:54 AM
New hub/bearings or rotors bstuby Suspension & Brakes 8 02-15-2011 12:03 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
