Break In for EBC Green Stuff Pads w/ New Rotors
As the title states i put on EBC Green stuff pads and New rotors. The EBC pads have the Break in coating on them, and they say to do the following."In Street use situations …
Bedding in when the red EBC surface coating (marked on the pads as Brake In) is applied.
Best procedure is to drive gently avoiding harsh braking unless in an emergency for first 100 miles. In the second 100 miles (up to 200) you can use gently increasing brake pressures when using the brakes.
Only after 200 miles urban driving (not 200 miles on a freeway where brakes are almost unused) should you attempt to apply heavy load and heat to the brakes. To do this final bedding on a QUIET ROAD in safe traffic apply the brakes and slow from 60 to 10 MPH five times in a row. Then drive slowly for a few minutes if safe to do so to allow the brakes to cool. Try to avoid coming to a rest whilst the brakes are heated.
A smell may be noticed from the warm brakes, this is normal. Repeat this procedure a second time after the brakes have TOTALLY cooled down. EBC pads get better with miles. Even after this bed in procedure it can take up to 1500 miles before the pads are at their best. In the meantime the pads will be good and safe but true potential not realised. EBC makes performance pads that last, they do not bed in within 5 minutes driving. Noises will be more likely during the first 1000-1500 miles use whilst this chemical bedding takes place.
However everthing else i read about break in procedures for pads is to do the 60mph to 10 mph stops immediatley after install? Just curious as to what others have done w/ these pads. Thanks.
Originally Posted by ultraz
HAWKS reccommend breaking them in right away with 25-0, 45-0 , and 55-0 stops until you see and smell a little smoke.
Do not completely stop when bedding new pads!
Ben T.
Originally Posted by Studytime
NO! You do NOT want to do this. You should NEVER completely stop when bedding in new pads. Don't allow the brakes to lock or ABS to engage either. You stop from speed to around 10-15 mph. This will ensure that you do not put an uneven transfer layer of pad friction material on the rotor.
Ben T.
Ben T.
The actual procedure varies.
The purpose is basically 2 fold.
1. Heat cylce the pads a few times in order for them (and the rotors) to "cure". Curing will prolong life, limit dusting and limit fade
2. Scrubbing in the pads under controlled conditions "sands" way the high spots on a brake pads and "beds" the pad surface to the rotor surface. This will give you near 100% effect pad surface area in contact with the rotor
Personally, I don't think the actual PROCEDURE is as important as the PROCESS itself.
