C6 Z06 Brakes on F-body?
Originally Posted by jargan04
Dont waste your money on them. There plain junk. The right front rotor turns backwards, the pads are thin and ware fast. Your better off with C5 brakes are a real aftermarket brake kit.
Extreme-Plus brake system from Baer. Part# 4301002 inlcudes 14" x 1.25" slotted & drilled rotors, new 6 piston mono-block calipers, pads, steel hoses, and mounting hardware. It runs $2925 and requires 18" wheels or larger.
Originally Posted by KCFormula
He told me that GM uses 2 "LEFT" rotors on the car, instead of building 2 different rotors they use a single rotor for both sides. (Which means the veins inside the rotor spin backwords on one side) But I also know some European cars do this as well so it can't be all that bad.
If everyone else jumped off a bridge......
