Front and Rear Sway Bar Diameter?
Old 09-25-2006, 10:35 PM
2kta--89formula's Avatar
Default Front and Rear Sway Bar Diameter?
I'm tired of searching, could someone help me out? I have a 2000 Trans Am <non WS6> and need to know the diameter of the front and rear sway bars. I see that a couple different sizes were offered, I don't have anything at the moment to measure them. Also, if anyone knows the part # for the front and rear energy suspension bushing/end link sway bar kit that'd be great too!
Thanks!
Old 09-26-2006, 01:27 AM
Krab's Avatar
If I'm not mistaken, your car comes with a 32mm hollow front bar and a solid 19mm rear bar. Don't know the part number for the endlink set, but if you have an Autozone locally, just go and ask which ones are for your car.
Old 09-27-2006, 12:20 AM
jmilz28's Avatar
Nope, 30mm front and 19mm rear. You need to know that so you can tell AZ what to order. SS/WS6 standard was 32/19. Some of he SLP cars got 35/22 setup. Measure to be sure. Better yet, call Sam Strano and get your stuff from him. If you try and save $10 by going to AZ, you WILL be sorry. Don't ask me how I know...
Old 09-27-2006, 12:50 AM
Azrael's Avatar
He is right you have a 30mm/19mm. The front will have a tag on it usually, KAA is the V6, KAB is the 30mm (Formula, Z28, Trans Am), KAC is the 32mm (SS, WS6, Firehawk).
Old 09-28-2006, 01:57 AM
Krab's Avatar
My bad about the wrong front bar size.
Old 09-28-2006, 08:33 AM
warp10's Avatar
32/19 on my Hawk.
Old 09-28-2006, 11:38 AM
coolformula's Avatar
I never heard of a stock 4th gen with a 35mm front bar?
Should be 30mm for non ws6
Quick Reply: Front and Rear Sway Bar Diameter?
