Squeaking noise driving me crazy
Old 11-10-2006, 02:21 PM
The SSheriff's Avatar
Default Squeaking noise driving me crazy
I have a 1999 Camaro and I have the Bilstein Shocks with SLP Valving, Eibach Springs and 1LE front sway bar with Polyurethane bushings. Every time I go over a speed bump, I consistently hear squeaking FROM THE FRONT and it's not only when the car is cold either. I tried getting under there to grease some things up to find that there are no nipples anywhere.
How do I get rid of this squeaking problem. The car was 71,XXX miles on it, and babied 95% of the time.
Old 11-10-2006, 06:17 PM
jpat1023's Avatar
Get rid of the squeak, huh?? Are F-body owners even allowed to do something like that? I thought all possible rattles and squeaks were required for f-bod ownership?
Seriously though, you will probably have to buy a new car to satisfy your squeak tolerance.
Mine does it too, but it is off and on...actually, now that I think about it, I haven't heard it in at least a month...
Old 11-10-2006, 08:21 PM
I hate it though. Could it be the springs or struts??
Old 11-10-2006, 08:46 PM
TXAgZ28's Avatar
Try greasing the bushings...
Old 11-10-2006, 09:02 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
YUP.
Old 11-11-2006, 09:46 AM
ShevrolayZ28's Avatar
The end link bushings were squeaking on my car. Also check the tie rod ends.
Old 11-11-2006, 07:46 PM
I have never greased up these bushings before. Instructions??
Old 11-11-2006, 08:10 PM
White 96LT1's Avatar
Don't go over speedbumps then
Old 11-13-2006, 09:43 AM
Instructions? TTT
Old 11-13-2006, 10:23 AM
01WS6er's Avatar
My car squeaks worse in the rear when it is cold. It does squeak when it is warm but not as much. I have done nothing to my suspension and it only has 19,5xx miles.
I put PSTpoly-graphite bushing in my truck when I lifted it and they squeak. I have just gotten used to them . I have pulled them apart several times and used several diff types of lube to find no fix. Good luck on yours.
Quick Reply: Squeaking noise driving me crazy
