removing front control arm?
Old 01-14-2007, 07:38 PM
winston01's Avatar
Default removing front control arm?
i'm putting a new control arm on my 01 ws6. the problem is i cant get one of the two blots out of the k-member (the vertical one) is there any suggestions on how to push this bolt up thru?
Old 03-22-2007, 08:21 AM
1QUIKTA's Avatar
Did you ever find an answer? I am having the same problem.
Old 03-22-2007, 10:19 AM
you2slo's Avatar
Is there still tension on the lower A-arm? I had to use a large hammer to pound it out.
Old 03-22-2007, 11:02 AM
1QUIKTA's Avatar
I have tried with and without tension and a 10lb sledge. Almost a whole can of PB blaster is gone as well. I am going for an air hammer next. This is freakin insane. No wonder he couldn't align the car. Can't get the bolts loose.
Old 03-22-2007, 12:35 PM
you2slo's Avatar
Is the lower A-arm bent at all? Are you going to replace it? I hit a curb and bent mine almost in half. I had to break out the sawz-all to cut it into 2 pieces. I then could remove the bolt.
Old 03-22-2007, 01:46 PM
1QUIKTA's Avatar
I really don't know if it is bent. The tech said maybe, but couldn't give me an answer. I matched up one from my 97 and it was right one. Before I took it in it was just a tick off, now it is crap. I think something screwy is going on at the alignment shop. F@#$ it, I am just putting her back together and someone is getting a better deal on the sale.
Quick Reply: removing front control arm?
