Ran dry on brake fluid!?! HELP
Old 04-15-2007, 03:11 PM
The PAT WS6's Avatar
Default Ran dry on brake fluid!?! HELP
i was in the process of puttin on my new rotors and pads and i had the calipers off cus iwas painting them and i forgot to put a vice grip on the two front and all the fluid ran dry?!?! i have heard its not good if u let the system run dry? it ***** with the abs or somthing? am i right.
i was gonna bleed the whole system anyways with super blue ate fluid but i didnt wanna run it dry.
ccan anyone chime in here, before i get myself in a deeper situation.
thanks.
Old 04-15-2007, 04:25 PM
EDS01SS's Avatar
Hate to tell you this but your pretty much screwed. You can try bleeding the system manually and hope the ABS module didnt run completely dry but I doubt it.If you arnt lucky and it did run completely dry get it to the dealership to have it bled. To properly bleed the abs system you must have a tech2 scanner to open and close the abs valves
Old 04-16-2007, 12:04 AM
everything is good i did not run comp. dry
thank good ness
Quick Reply: Ran dry on brake fluid!?! HELP
