Abnormal Tire Wear
Old 05-08-2007, 08:50 PM
KCS
Moderator
KCS's Avatar
Default Abnormal Tire Wear
So I looked under the car today and noticed that my driver's side tire is worn bald, while my passenger side is fine. Not only that but the inside is showing steel belts, but the outside isn't.
The only suspension mods are weld in subframe connectors and an adjustable Panhard rod. I just kinda eyeballed it when I re-centered the rear axle, don't know if thats gonna make a huge difference. The only other thing is that a wheel stud is broken on that side too. Just one though.
If anybody has any ideas on which direction to go, I'd appreciate the help. My Mom's birthday and mother's day are all in the same week so I'm working with a tight budget here. Thanks in advance.
Kent
Old 05-08-2007, 09:32 PM
DMSZ28's Avatar
the car is lowered too. Pro kit
Old 05-08-2007, 10:03 PM
TXAgZ28's Avatar
You need an alignment.
You probably have too much negative camber, which causes the inside of the tire to wear prematurely.
Old 05-08-2007, 10:04 PM
jond99's Avatar
The lowering kit will mess your alignment up. Whats happenning to your drivers side tire is common when you lower your car and don't get an alignment. Unless you hit something on that side than take it to an alignment shop.
Old 05-08-2007, 10:41 PM
DMSZ28's Avatar
its the rear tire
Old 05-08-2007, 11:18 PM
HIPER-Z's Avatar
Alignment for sure, same thing happened to my buddy.
Old 05-09-2007, 07:51 AM
trackbird's Avatar
Toe out will kill the inside edges of tires even faster than negative camber. Get to an alignment shop and get it checked out/realigned.
Old 05-09-2007, 08:29 AM
BigBronco's Avatar
Too many Burnouts Kent
Old 05-09-2007, 12:38 PM
KCS
Moderator
KCS's Avatar
That was my initial thought, but it's significantly worse on the driver's side. The entire tire is bald while the wear on the passenger's side is barely noticeable. Could the rim be bent somehow?
Old 05-09-2007, 12:39 PM
KCS
Moderator
KCS's Avatar
yeah, but chicks love it!
Old 05-09-2007, 01:41 PM
trackbird's Avatar
You can have differing toe on the front wheels and wear one side more quickly. If the wheel was bent, you'd usually only see bad tread in one spot, or on opposite sides of the wheel and not what you describe.
Old 05-09-2007, 02:57 PM
EDS01SS's Avatar
have the alignment checked and have them check the ball joints while their in there
Old 05-09-2007, 10:11 PM
KCS
Moderator
KCS's Avatar
These are the rear tires.
Old 05-09-2007, 10:12 PM
KCS
Moderator
KCS's Avatar
I appreciate all the help so far guys, thanks alot. I'll get this thing to a shop to get the alignment checked.
Old 05-10-2007, 06:55 AM
trackbird's Avatar
Someone else said that, but it wasn't you, so I didn't think they were serious.
In that case, I'd start looking for a bad shock on that side with the dead tire. Of course I'm assuming that the axle isn't bent/tweaked enough to give you a bad toe setting (it should show up on an alignment rack). It's usually the right rear (passengers side) tire that wears out first, if you're wearing the other one, I'd start by checking the shocks (or swapping them from side to side).
Or, do you hammer the throttle around a certain corner every day/often? That's another possibility.
Quick Reply: Abnormal Tire Wear
