v6 rear springs???
v6 rear springs???
I've got a 99 ta...just wondering i know some people run the v6 springs in the rear for racing... whats the benefit and will it lower the rear of the car any? any idea what the spring rate is???
Location: Your girl's back door giving her the long stroke while you're at work
If you want to lower it on the cheap then take the rubber isolater off the top of the spring and put heater hose around the first coil
Yeah, don't go out and get a softer spring for the purpose of lowering your car. If you're looking for weight transfer at the dragstrip, that's one thing, but expect handling to get weird having a 20% softer spring in the back.
Like mentioned above, for lowering the rear to level the car out, remove the isolator from the top of the spring and slip heater hose over the spring.
