Rear brake hose
Old 05-24-2007, 10:24 PM
HavATampa's Avatar
Question Rear brake hose
Can someone verify that the rubber brake hose that goes from the chassis to the differential on a non TCS F-body has the following fittings:
(1) M12 x 1 THD female connector on one end and (2) 3/8" -24 female connectors on the junction block.
Old 05-25-2007, 01:21 AM
hotpart's Avatar
Our build catalog for the hoses we produce is showing a M12 x 1 clip mount with a DPS seat. The hex should be 16 MM with oval on two sides, this is on the chassis side and on the axle side it is showing 3/8NF x 2 (bolt mount tee) with an inverted seat and the hole should taper from 10mm to 8mm.
Old 05-25-2007, 07:01 PM
HavATampa's Avatar
Good info on the connectors. Thanks. Can you build me an 18" hose with the correct fittings? PM me if necessary.
